Old 02-13-2010, 02:44 AM
sisko89 sisko89 is offline
Door Handles
How to replace the exterior door handle,both sides,on a 1992 Chevy S10 pick up. What tools are needed?
Old 02-13-2010, 08:43 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Door Handles
To replace door handles remove the inside panel to get to door handle hold on bolts/nuts.
A inside panel clip tool helps.
Also a inside door and window handle clip release tool.
And catch that clip when it pops off.
MT
Old 02-13-2010, 06:36 PM
Re: Door Handles
Thanks for the reply,it does help. I have never done this before,so detailed
instructions would be helpful. Is there an online exploded view of the door?
Old 02-14-2010, 09:27 AM
MT-2500's Avatar
AF - Advisor
Re: Door Handles
A factory repair manual would be best.
or a all data sub.
http://www.alldata.com/products/diy/index.html
Most public libraries have car repair info and lot online.
Also check Auto zone web site.
But the procedure is not that hard.
Just remove inside door panel and you can see back side of door handle.
Good luck and let us know how it goes.
MT
Old 02-14-2010, 09:30 AM
jd-autotech jd-autotech is offline
Re: Door Handles
you maybe able to get a manual from your local library and there are part stores that rent tools.
Old 02-16-2010, 03:53 PM
Re: Door Handles
Got it done. Not to hard a job for first time.
The hardest part was seeing inside the door and getting clip on rod to open door. Not much room. The inside panel was a little difficult to get off because of the retainer clips. The whole job took two hours for both sides.
Old 02-16-2010, 04:11 PM
MT-2500's Avatar
AF - Advisor
Re: Door Handles
Thanks for posting back how it went.
Yes retainer clips can be a pain.
Good luck.
MT
Old 02-16-2010, 08:17 PM
Re: Door Handles
Another hard part is that it is cold which makes all of the parts harder to handle. I broke one clip on one new handle trying to push the rod through it.
Went to parts store and bought four extras.
Broke a few interior panel clips trying to twist those in place.
If it was summer time it would have gone faster and smoother.
