Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 02-12-2010, 10:42 PM
Leche Leche is offline
Wiring help/questions....Headlights
I just recently purchased some Halo/Projectors for my 01 2500 Suburban. The question I have is on the wiring for the Halo's and then the LEDs on the headlamps. The Halo's on each headlamp come with one red and one black wire. I'm sure the red is my power (which will tap into the parking light wire) and the black (will go onto the ground wire). Also there are two LEDs on the end of the headlamp. One White wire (would this one by my power?) and a black (The ground?), These two would hook up the same onto the Parking light wire correct? I spoke with the seller of the lights and they mentioned that one is positive and negative. Looking at the wiring I was just going to splice the two reds on the Halos together and hook them up with wiring taps I got from an auto parts store into the factory harness, and do the same for the black wires onto the negative. Would this hinder the lights in operating the way they should? And I was going to do the same for the LED's, this way I reduce the amount of taps into the parking light and grounds wires on the harness. My last question is. Tapping into the Parking light wire so many times on each side (2x each), would this create a problem?
Old 02-13-2010, 08:40 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Wiring help/questions....Headlights
If you are adding lights.
Use a complete separate wiring setup on them.
If you try to tie into the OEM wiring you can cause many problems.
MT
Old 02-13-2010, 08:55 AM
Would an auto parts store have something like this. The wires are just there with no type of harness.
Mozilla/5.0 (Linux; U; Android 1.6; en-us; T-Mobile myTouch 3G Build/DMD64) AppleWebKit/528.5+ (KHTML, like Gecko) Version/3.1.2 Mobile Safari/525.20.1
Old 02-13-2010, 09:55 AM
Also am I going to need any fuses to connect to to prevent any damage?
Old 02-13-2010, 10:33 AM
MT-2500's Avatar
AF - Advisor
Yes parts places have all kinds of wiring and external fuse holders and external switches.
On wiring jobs I like to solder all connections and use heat shrink and use sealer where there is moisture.
Yes always fuse your circuits.
Also run wires where the do not rub or burn.
MT
Old 02-14-2010, 07:30 AM
Thanks for the info
