Go Back   Automotive Forums Car Chat > Mazda > 323/Protegé/Familia/Etude/Allegro
Old 02-12-2010, 08:55 PM
cspring cspring is offline
93 Mazda Protege shuts off after hot
I have a 93 Mazda protege. The car runs great when cold but after it heats up the car hesitates and dies. It will not run right until after I let it cool down for awhile. I replace the plugs, wires, cap and rotor, fuel filter and TPS. Any help would be appreciated
Old 03-22-2010, 06:23 AM
shadrach mowarin shadrach mowarin is offline
Re: 93 Mazda Protege shuts off after hot
I have a similar problem with the 2000 protege.Changed COP, crank sensor.No way.Intermittent code from scan tool reads "NO CMP OR SGC signal" . Still shopping for the CMP sensor and ultimately may change the ECU.Am not sure as I still dont have a sure clue.
Old 03-25-2010, 06:00 AM
Flash75 Flash75 is offline
AF - Advisor
Do you have ignition spark when the engine dies? If not I would check the coil.
Clifton
Old 04-04-2010, 02:18 AM
thanx.Its intermitent failure from the camshaft sensor.Waiting for delivery.I will feed you back.
