Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 02-12-2010, 07:30 PM
PBR streetgang PBR streetgang is offline
2003 SLE heated seat problem
Thought I would check with you guys before I tear into it. My 03
SLE drivers heated seat went out the other day. When first turned on, the ind. light comes on for 1 second & then shuts off. I also noticed the on/off switch is no longer illuminated. Passenger side appears to work OK. Any help on where to start would be greatly appreciated.
Old 02-13-2010, 02:26 PM
Re: 2003 SLE heated seat problem
I swapped out the relay box with passenger seat..... that was not the problem.
Old 02-17-2010, 10:22 AM
Jrs3800 Jrs3800 is offline
The problem is with a wire burning out inside the seat... Some of the guys I deal with on another forum have taken the seat apart and pulled the seat skin and repaired the problem area/s to regain the heated seat function..
Old 02-17-2010, 02:03 PM
My next step was to hunt down the thermo switch/sensor but not sure where to look. I'll keep an eye out for anything burnt or broken.
Old 02-22-2010, 05:18 PM
jdq jdq is offline
I just tried to fix mine to no avail, it is usually a wire in the ass part of the seat, you can pull the leather skin off and probably see a burn mark.I found the burn mark and tried to solder wire together but seat dont work still.Others have soldered it and it worked.
2000 bonn ssei 155000 klm
1997 dodge caravan 92000 klm
