Go Back   Automotive Forums Car Chat > Chrysler > Sebring | Sebring Coupe | Convertible
Old 02-12-2010, 02:45 PM
dayday1920 dayday1920 is offline
jerks when stopping
I just replaced the seal and changed trans fluid now car jerks when coming to a stop, why?
Old 02-12-2010, 08:54 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: jerks when stopping
If it does it when you are applying the brakes, your brake rotors are warped and need resurfacing. If you can take them off yourself, you can have them turned for $15-$25 at most brake shops. Otherwise it'll be more expensive.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 02-13-2010, 12:22 PM
ninesevenvert ninesevenvert is offline
You might have used the wrong fluid.. it depends on the year, some use ATF3 and some ATF4. You might give your local Dodge dealer a call to find out. My car used to jerk when stopping, like it shifted a little late when stopping. Since I had to replace the engine, I went ahead and replaced the seals on my trans..and I used ATF4. I also put in 8 and a half quarts..the trans only holds 9. If you just replace the pan and filter it is around 4 and a half.
