Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 02-11-2010, 02:10 PM
hellah fresh's Avatar
hellah fresh hellah fresh is offline
99 Dodge Ram 5.9L new ALT not charging
Hello everyone! I have a 99 Dodge Ram pickup 1/2 ton 5.9L gas engine and we installed 2 new alternator and it is not holding charge. We have the voltage meter hooked up and it reads between 11-12amps while running. So yes it not staying at 14 like i should. I looked around online and some forums was reccomending a bad Voltage Regulator and i called autozone and they said that the VR isnt availble and it might be on the alternator already. Does anyone know what is wrong and why it isnt charging at 14amps?
1996 Mitsubishi Eclipse RS -Red ****UPDATE**** My car is no more! R.I.P. 12/12/05
Mods: 420a DOHC equipped with: bored 54mm throttle, 2.5" cold air intake, 2.5 chrome headers, 2.5 Down Pipe, 2.5 resinator, 5" 2.5 flared muffler, 2.5 custom piping, Megan front & rear strut, Megan rear lower tie rod, Monroe Shocks, Aerospeed coilovers
Rollers: 18" TSW Throphy / Pirelli P7000 225/40/18
Old 02-13-2010, 07:20 AM
2000izusu 2000izusu is offline
Re: 99 Dodge Ram 5.9L new ALT not charging
the voltage regulator is in the pcm, but i would check all the grounds first. did they test the reman alt before you took it out of the store?
2006 liberty 3.7 6speed manual
1999 cherokee classic 4.0L
1991 wrangler yj 2.5L
2001 caravan 3.3 auto
1995&1992&1994 camry 2.2L SOLD
1991 silverado 1500 SOLD
2000 rodeo SOLD
Old 02-21-2010, 06:29 PM
kevinb70 kevinb70 is offline
Send a message via AIM to kevinb70 Send a message via Yahoo to kevinb70
ground
big fuse in power distribution box
the connector which powers the field coil-- if there is a short there/loose wire, your alternator will spin all day long and not put out any power.
check that b4 u even think about replacing the pcm
