Old 04-12-2003, 01:15 PM
ZORT ZORT is offline
autometer quick shift light on a fields vtec controller
I am trying to hook up an autometer quick shift light to my fields vtec controller. So that instead of the buzzer coming on I will get the shift light. I took out the circut board from the fields but don't know where to tap. Does anyone know where i can get the wiring diagram for the fields vtec controller (boxer series)? Or know where on the board i can tap.
Old 04-13-2003, 07:14 AM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
without thinking about it REAL hard, I would suggest tapping into the same signal that the buzzer is on ...
Old 04-14-2003, 06:20 AM
That is correct but the buzzer is not a speaker
That is exaclty what i thought I would see when i opened the controller but the buzzer is a plastic device and is soldered to the circuit board. The problem is that i don't know which wire to tap.
Old 04-14-2003, 02:42 PM
Audio Guy
that might be tuff .... look and see if you can follow the traces, one lead might go to an IC and the other might go to a ground
Fields Vtec Controller Vcity1 Engineering/ Technical 3 05-10-2003 02:45 PM
autometer quick shift light on a fields vtec controller ZORT Forced Induction 0 04-14-2003 06:29 AM
Tuning a supercharged b16a engine with a fields vtec controller ZORT Forced Induction 2 04-10-2003 10:24 AM
apexi or fields vtec controller setting 13devils Engineering/ Technical 0 12-20-2002 02:04 PM
field vtec controller nguyen80 Accord/TSX/Accord Hybrid 0 08-29-2002 10:49 AM
