Go Back   Automotive Forums Car Chat > Isuzu > Trooper | SLX | Bighorn | Wizard
Old 02-11-2010, 01:44 PM
buts buts is offline
4X4 not working
I have a 2001 manual transmision the 4X4 does not engage and the 4X4 light just stays falshing. In 4X4 the low gears doe engage on the rear but the light still flashes and the front wheels never kick in. Any sugestions ?
Old 02-18-2010, 12:37 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Re: 4X4 not working
Locking and unlocking of the fropnt axle is controlled by vacuum switching valves. They are mounted on the front axle, drivers side. The most common failure in those is an internal leak (could also be a vacuum or electrical problem). There's also a switch that senses when it's locked or unlocked. That is telling the ECM it isn't locking, which gives you the flashing light.
The part is around $75 online and about 20 min to install.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 02-23-2010, 07:54 AM
Re: 4X4 not working
Thanks for the information. Do you have a part number or will advance auto know what I need ?
Old 02-23-2010, 08:02 PM
fourwd1's Avatar
AF -Advisor
Re: 4X4 not working
Advance Auto or anywhere else won't have a clue what you're talking about.
It's a dealer only part. And as I said, it's "the most common failure" but not the only possibility. It could be a vacuum leak elsewhere or an electrical problem. You may want to do a little troubleshooting first.
If you want to just go for it, I think the p/n is 8-97101-858-1.
Just call St Charles Isuzu, ask for Merlin, tell him you need the VSV unit for the front axle. You heard about them on this forum.
89 4Runner - stock
