Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 02-10-2010, 10:27 PM
smbonneville smbonneville is offline
key less entry swap
could i take the keyless entry out of a 1999 olds intrigue and install it in my 1996 bonneville?
Old 02-19-2010, 04:24 PM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
Re: key less entry swap
Each car uses a different remote type so if you plan to use remotes from the Intrigue on your Bonneville, that will not work.
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
Old 02-20-2010, 07:54 PM
Jrs3800 Jrs3800 is offline
If you were going to use the system from a 96-97 H or C body then yes you could make it all work... If the car is not equipped with keyless this will be a bit of a PITA for you...
The 99 Intrigue will not work for you..
Also look on your spare tire cover for the SPID( RPO Code List )
do you have
AU0 This is the option for keyless
1SB or ( 1SB usually will not have keyless )
1SC or ( More than most these came with keyless )
1SD ?? ( This is the SLE Package and included keyless, In some cases with this package AU0 will not be listed as its part of the 1SD equipment group )
Old 03-17-2010, 06:55 AM
HotRod53 HotRod53 is offline
I have a '98 SE that came with electric locks but did not come with a keyless remote. I was able to purchase an aftermarket unit from Ebay for about $25 and install it. If I recall correctly there are 2 relays up under the dash by the glove box. You find the trigger wires and tap right in.
Tags
entry , intrigue , keyless , olds
