Old 02-10-2010, 09:27 PM
FireDude312 FireDude312 is offline
Any Ideas? :-(
While running around today in the snow in 4 wheel drive, I had a problem :-(
I was driving in 4 HI, and running fine. I pushed the 2HI button, heard the change over, and continued driving. I came upon straight blacktop, and continued driving. After about 5 seconds, the blazer started pulling to the right. I let off the accelerator, and it came grinding to a halt. It made some rough sounding noises when slowing down (girinding, bang).
Now when I hit the 4HI button, it clicks, engages, works, but makes a grinding noise from the front or near the middle it sounds like.
Am I completely hosed? :-(
Any idea's where I could start?
Old 02-11-2010, 08:57 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Any Ideas? :-(
Start with looking for where the grinding is from.
MT
Old 02-11-2010, 12:14 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: Any Ideas? :-(
Three things come to mind...brake caliper, hub bearing assembly, and CV joint. Since it happened while you were driving, not braking, I'd suspect one of the latter two. However, jack up the front and give the wheel a spin to listen for the sound. If it feels locked up, then I might suspect a stuck brake caliper...did the wheel feel very hot when you came to a halt?
That's where I'd start. Good luck!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
