Old 02-10-2010, 07:45 PM
Sergey_t Sergey_t is offline
cavalier leaking oil real bad when running
Hi, i have a 1996 cavalier 2.2 liter. The car leaks oil real bad when it is running, also the oil level is way overfilled. My question is, do you guys think its leaking oil that bad because it is overfilled, if not what else could it be. Tommorow im gonna drain the oil and put it back to the normal level. Im also going to the junk yard tommorow, so any advice before then i would appreciate. Thanks
Old 02-10-2010, 08:06 PM
rhandwor rhandwor is offline
Re: cavalier leaking oil real bad when running
Try to determine where it is leaking oil. Look at the front and rear main seal.
Look at the oil pressure sending unit is it leaking. Is it leaking around the head?
Tell us what is leaking and we can help you.
Old 02-10-2010, 08:10 PM
ok..it is engine oil that is leaking for...the oil is not brown or black...its clean like straight from the jug....its leaking towards the back of the engine..its not leaking from the oil pan...thats all i can provide for right now...since its dark outside at the moment here in spokane...but tommorow morning il try to find out more...
Old 02-10-2010, 08:12 PM
oh yea...and where is the oil pressure sending unit? thanks
