Old 02-10-2010, 06:35 PM
jerry1967 jerry1967 is offline
2003 heater blower motor
I have a 2003 LeSabre 3800 engine. I have good heat just that the blower motor doesn't always run. I assume the motor needs changing but I have never done this before so I was wondering if anybody has a picture of the engine with a close up of the blower motor.
Old 02-10-2010, 09:25 PM
danielsatur danielsatur is offline
Re: 2003 heater blower motor
Check with www.alldata.com , it could be just a resistor.
Old 02-10-2010, 10:07 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Do you have auto climate control?
Old 02-10-2010, 11:32 PM
No it is the manual kind.
Old 02-10-2010, 11:35 PM
How do I tell if it is just a resistor?
Old 02-11-2010, 05:22 PM
imidazol97 imidazol97 is offline
AF -Advisor
If it runs sometimes and seems to start if you hit a bump it may be bad brushes in the motor. I could take the toe of my shoe and tap the blower motor gently and the vibration would cause contact and everything was fine until I turned it off. Then about one tenth of the time it wouldn't have contact.
When I replaced it with one from Autozone, I took the old one apart. One of the brushes seemed stuck in its channel. Both were worn unevently and the commutator was rought.
$139 IIRC.
The motor is inside the car, next to the hump. There's a panel to take off with a few screws to give access. Disconnect the power connector. Remove 3 screws. Take off the rubber hose that ducts air back to the motor for cooling. Wiggle the motor and attached blower cage out without pulling the carpet away from the area even. Plenty of room.
Old 02-11-2010, 05:33 PM
www.alldata.com ,has OEM service and repair info, sorry mine expired.
