Old 02-10-2010, 11:54 AM
Johnson5 Johnson5 is offline
4 wheel drive does not work
I have a 1995 Chevy K3500 that the 4 wheel drive doesn't work. I have replaced the actuator and checked the fuse in the dash, still no 4 wheel drive. Any suggestions on what I could try next? This is a 454 4 wheel drive automatic
Old 02-10-2010, 04:43 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 4 wheel drive does not work
What part is not working?
Is front drive shaft locking in?
Is actuator locking front axel in?
Does transfer case shift to low range?
What transfer case have you got?
Id tag on back of it?
Have you checked all fuse for 12 volts both sides?
Is this obd11 or OBD1?
MT
Old 02-10-2010, 05:39 PM
j cAT j cAT is offline
with no 4X4 operation the encoder motor located in the transfercase , only places the drive train in 4WD..
the front diff gear box ACTUATOR only locks the front axle together ...this does not engage the 4wd..
could be bad motor , bad electrical ..depends on your setup....
Old 02-11-2010, 08:33 PM
troy1 troy1 is offline
AF -Advisor
Switch on top of the T-case stuck?
