Old 02-09-2010, 10:07 PM
jayjp200 jayjp200 is offline
98 Windstar Transmission internal wire harness
I have a damaged transmission internal wire harness on my 3.8 liter 98 Windstar.
Can I replace it without dropping the transmission!
Did any one do this. Please give me some directions.
I have attached a picture here.
Thanks.
Jay
Old 02-10-2010, 12:32 AM
wiswind wiswind is offline
Re: 98 Windstar Transmission internal wire harness
I posted in your other thread what connects to it.
I do not know if it can be done on the vehicle or not.......
I posted what the pin-outs are....with wire colors.....but that is for my '96.
The other post.....for the plug on the vehicle wire harness......tab at the top.....pin 1 is top left.....then you go to the right.....pin 4 is top row....right.....blank/not used
Pin 5 is 2nd row left....
Pin 9 & 10 are bottom left & right.
So, on the transmission connector......the one that is broken.....
Top RIGHT is pin 1.....SS1 Orange Wire
Pin 2 is Power to all 3 shift solenoids..... RED wire
Pin 3 is TCC Brown
Pin 4 top left.....blank/not used
Pin 5, 2nd row right TFT Black wire
Pin 6 is SS2 Pink wire
Pin 7 is Power to TCC & EPC Green Wire
Pin 8 is SS3 Yellow wire
Pin 9 bottom right is Signal Return from Transmission Fluid Temp (TFT) White wire
Pin 10 bottom left is EPC Blue wire
I don't know if this will be of any help......please remember that this is for 1996, as that is all I can see in my Alldatadiy subscription.......much is the same for 1996-1998
I am thinking that this might help in case you can locate another connector body......to match up what pins/wires go to what hole.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 02-21-2010, 02:09 PM
Thanks for the response Wiswind!
I have managed to replace the wire harness which I damaged it due to my stupidity.
I removed the transmission support and lowered it with jack. Removed the side cover and connected the new harness.
Thanks once again.
Old 02-21-2010, 04:49 PM
It is great to see that you were successful!
Now I know where the electrical connection is.
1996 3.8L Windstar
