Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 02-09-2010, 06:21 PM
phantom1131 phantom1131 is offline
3.4 Engine Knock
just did IMG job on 2001 venture 3.4.....had to put a helicoil in one the valve spring bolt holes in front head.....the engine is now knocking while running...pulled the front valve cover and retightend the lifter bolts,still knocks...i know i did not mix up the rods or drop anything in engine...is it possible to break valve spring or make lifter stick by over torque..spring does not appear broken...any thoughts would be extremely appreciated....thanks...jim
Old 02-09-2010, 07:41 PM
lesterl's Avatar
lesterl lesterl is offline
Re: 3.4 Engine Knock
Could be a collapsed lifter..... Did you change the oil after everything was apart.
1997 Chevrolet Venture SFI 3.4l Auto 249k
2006 Chevrolet Malibu Maxx SFI 3.5l Auto 81k
http://www.s10forum.com/forum/attach...nsor-chart.gif
Old 02-09-2010, 07:43 PM
lesterl's Avatar
Collapsed lifter... Didja change the oil afterwards?
Old 02-10-2010, 12:12 AM
sure did, i never let it run for more than probably 30 seconds at a time because of the knocking...i did this four or five times..figured oil should have made it up by than...don't want to do any more damage....how long should it run to get normal after the IMG repair...i can understand some slight knocking/ticking,rough idle, etc. on first start up.this is a loud knock....
Old 02-10-2010, 04:33 PM
kornjulio kornjulio is offline
Is it a bottom-end knock or lifter noise?...Also, what do you mean by "valve spring bolt holes"...was it a rocker arm stud???
2000 Venture - repairs to date:
LIM gasket, water pump, wiper park position, front wheel bearings, rear wheel bearings, flickering lights, blower motor resistor, door speaker corroded, rear hatch handle, rear wiper motor, front struts, busted sway bar, LCA bushings, hard shifting tranny (new solenoids!)
Old 02-23-2010, 10:20 PM
it is that repair on the lifter bolt hole in front head.....pulling head a taking to machine shop and/or replacing head...thought at the time i should just pulled head then...oh, well
Old 02-24-2010, 09:49 PM
lesterl's Avatar
If it is a loud constant knock, it could be a rod, even if it is sounding like it is top end the piston could be striking the head because the Rod bearing is toast (several out really sounds badass untill the engine siezes, ask me how I know!!!!)
