Old 02-09-2010, 03:15 PM
hollis87 hollis87 is offline
94 s-10 battery drain
got a 94 s-10 and i bought a new battery and it lasted 2 months and one day at a store i shut it off and wouldnt start up till i had it jumped and it continued to do so..got a new bat lasted 2 days and then did it again and i had it replaced 1 more time still the same.the alt. is good and so is the started i had 2 diff mechanics look at it and they are puzzled was wondering what could be doing this.also there is no inside or outside lights staying on iv checked anything i could think of but im not that good with cars any advice would be helpful
Old 02-10-2010, 09:04 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 94 s-10 battery drain
Is the battery actually going dead after setting?
Is alt charging good?
Is battery cables good and clean?
If battery going dead overnight or after sitting a day or 2 run a amp draw test on it.
Post back amp draw test results.
MT
Old 02-15-2010, 09:52 PM
jyount jyount is offline
This truck is old enough it should NOT light a test light when everything is right...
Disconnect the negative battery cable and put a test light between the cable and the post, as in break the connection except the test light, then start pulling fuses one by one until the light goes out, then figure out what is on the circuit the effected fuse has on it, and test accordingly. Let us know what you find.
10 hours away from John Deere master certified
also master certified ASE tech. Exp. in both.
Went to school for cars, wound up staying with Deere dealer for a while, so schooling there too. Also couple years exp in GM and some GM training
Gave up wrenching for "Greener Pastures"
Current job: RN
2010 Silverado Z71 5.3L 65xxx
Wife's
2007 Suburban 1500 LTZ 5.3L 102xxx
