Old 02-08-2010, 05:02 PM
khadma khadma is offline
Taurus help - Heater and front brakes
1999 Taurus 3.0 OHV
2 things
First - our heater does not put out heat, it used to but just went out.
The blower works fine. AC cold function works fine too.
Could it be just the rotory switch or the resistor?
Second - when the car is cold in the morning - applying the brakes from high
speed causes a wobble like condition in the front end (only when applying brakes).
Has anyone experienced this condition?
It really seems like the discs are not flat, I may just try replacing the
pads to see if it helps
Thanks,
Darren
1999 Taurus
1995 Windstar
1996 Bronco
2005 Escape
2002 F150
2007 Explorer
Old 02-08-2010, 09:11 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Taurus help - Heater and front brakes
Both conditions are pretty common and a quick search of the forum will yield several pages of details. Essentially the lack of heat is likely a restricted heater core which could be due to galvanic corrosion and/or dissolved impellers on the water pump.
Warped brake rotors are pretty common as well, but should not be dependent upon the ambient temperature. The pulsation when braking should be there warm or cold.
-Rod
