my 1993 caprice wont start. when i started looking for the problem i found that there is no fuel coming out of the injectors. since its tbi i put alittle bit of fuel in the trottle and it started up every time i turned it on, but after letting it sit for a while i tried to start it wasnt spraying fuel again. can anyone help???
Re: no start
with your 93 I don't have the pressure spec's ...search the forum or your repair manual... on my 1996 it is around 47psi...what ever pressure it is it should hold to with in a few psi. if it drops rapidly then you must locate the cause ....usually the fuel pump... |
Re: no start
Try the little things 1st!
1) fuel pump relay, fuse, and filter. 2) fuel pump pressure |
Re: no start
1993 TBI - fuel pressure should be 9-13 PSI.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1! 2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness! 1967 El Camino L79/M20 old school asphalt raper Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have. |
