Go Back   Automotive Forums Car Chat > Toyota > Solara
Old 02-07-2010, 11:01 PM
Edik90 Edik90 is offline
I need some advice: Regular or premium gas?
I was wondering what kind of gas has to be put into my 00 Toyota Solara SLE because I keep hearing that I should put in 87 octane but cars.com says that I have to put in premium 91+. If you could please let me know what you use in your Solara SLEs I would greatly appreciate it. Thanks!
Old 02-07-2010, 11:20 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: I need some advice.
Check your owners manual. It will tell you what to use.
Old 02-08-2010, 12:49 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Not to muddy the subject, but read the manual carefully. I'd trust the owner's manual over a website on a car's basic requirements.
If it says "premium unleaded fuel only" then you should only use the 91+ octane gas. If this is the case, the fuel gauge in the car will usually have this warning label as well.
If it says "for best performance premium fuel is recommended" or similar, then you should be able to use regular 87 octane gas.
To my knowledge and reviewing the specs, the Toyota V6 used in the Camry/Solara does not require premium fuel...while a bit high, the 10.5:1 compression ratio doesn't warrant it.
Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 04-15-2010, 08:00 PM
upssnowman upssnowman is offline
Re: I need some advice: Regular or premium gas?
The owners manual says regular is fine
Old 05-14-2010, 01:48 AM
Thank you gentlemen for your help!! I appreciate it!!
