Go Back   Automotive Forums Car Chat > Ford > General Discussion
Old 02-07-2010, 07:45 PM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Accuracy of FORD.ENGINE.TORQUE_C
I was looking at a few different PIDs I can log with my PC and found this FORD.ENGINE.TORQUE_C PID. I logged it and it clearly logs the torque of the engine, but not sure how accurate/usable it is. I Was also wondering if this is calculated for the torque at the flywheel, trans, or wheels. The highest I've ever gotten it is 250ft-lb at WOT and around 5100RPMs (100% load in second gear). When in Park/Neutral, it reads 0 but when in gear and stopped, will read around like 5-10 ft-lbs which is why I was thinking this may be calculated at the trans.
Anyone know how this is calculated and what it may compare like with true dyno results?
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
