Go Back   Automotive Forums Car Chat > Oldsmobile > Silhouette
Old 02-07-2010, 05:58 PM
DaColombian's Avatar
DaColombian DaColombian is offline
Cool 2001 Olds/Silo, Rear sliding windows problem
, This problem starts couple weeks ago. the drivers sliding power window don't closed/open, but the passenger works, today, I have the same problem but when pressing the switch the drivers side didn't closed, I did try couple times, now, both windows, don't closed, any feedback with this problem is appreciated.
Old 02-07-2010, 09:35 PM
roadrunner2 roadrunner2 is offline
Re: 2001 Olds/Silo, Rear sliding windows problem
You'll need a test meter or at least a continuity tester and make certain power is getting to the power window switches.
Moisture gets in these switches everytime the windows are open when it rains or snows.
Use a small screwdriver and carefully pry out the switch module out of the door arm rest.
You're going to have to test all the power wires and grounds from the fuse panel to the switches.
Years of opening and closing the front doors can and does make the wiring break where they pass through the door to the vehicle.
The problem with doing nothing is not knowing when you're finished.
Old 02-08-2010, 01:10 AM
GregA's Avatar
GregA GregA is offline
I agree with Roadrunner (testing is required), but I am not sure if you are referring to the windows that open together in the back of the van, or the front windows. Can you let us know which windows, exactly, you are referring to?
Greg A.
2001 Chevy Venture w/some "enhancements" ~ 105K Miles (Dec. 2010)
1992 Jeep Cherokee Laredo, 4.0L, Automatic ~ 155K Miles (Dec 2010)
Old 02-08-2010, 12:33 PM
I wondered at first too, but the rear windows only swing outward from the rear of the window about an inch and a half.
Then he goes on to talk about drivers door window.
Old 02-15-2010, 05:14 PM
Post Re: 2001 Olds/Silo, Rear sliding windows problem
Sorry, I was not connected since,. Yes, I'm requesting some info for the rear windows in this van, I did check all voltage and re-lubricate all mechanical parts, but. at the same time, I disconnect my control switch (top) and now everything is working correctly. Thanks a lot, for this feedback...!
Old 02-15-2010, 09:19 PM
Thanks for posting the end result.
It sure would be nice if everyone did.
