Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 02-07-2010, 12:22 AM
Hillcows Hillcows is offline
Send a message via AIM to Hillcows Send a message via Yahoo to Hillcows
Flat Rates?
Hi Everyone,
Need to have a radiator, Thormastat, hoses and engine strut mount replaced. Have taken it a few places and got totally different prices. I am thinking about doing it myself, but dont really have the time. Does anyone know the flat rate times on these so I have something to go on?
Thanks
Old 02-07-2010, 12:57 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Flat Rates?
It would be helpful for you to specify which engine and year Camry you are having work done on.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 02-07-2010, 07:22 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: Flat Rates?
DIY:
Radiator - $100-$150
Radiator cap - $7
Thermostat - $10
Thermostat gasket - $5
Thermostat housing gasket - $3
Hoses - $30
Hose clamps - $10 (if needed)
Engine mount - $100-$135 (for the big front or rear), $30 (dog bone or trans mount)
Coolant flush - $8 (add 2 gals of distilled water after draining out the flush solution)
Coolant - $26 (2 gals 50/50 premix, slightly less if you go 1 gal full-strength @ $14 and dilute with 1 gal distilled water @ $1 gal)
Drain pan - $10
These prices are for Gen III Camrys (1992-1996). Newer gens will be pricier for the radiator and mounts. Expect to spend the daytime on this DIYer since you'll have to remove the cooling fans and under side plastic deflectors and running the engine up to temp during the flush and drains then letting it cool. If your Camry's coolant hasn't been changed in a while, some pricier flushes let you drive for a hundred miles to dissolve more gunk & saves a step at change time.
Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
