2002 pontiac montana coolant temp
Things I know:
* Coolant Temperature Very Hot * Coolant Temperature Warning Light Goes On and Off * Radiator Cap is cold * Hose coming from right near radiator cap is cold * When heat is turned on inside the van cold air comes out vents at low RPM (3500-) * When heat is turned on inside the van warm/hot air comes out vents at higher RPM (3500+) * When heat is turned on inside the van at high RPM (3500+) with warm air coming out vent coolant temperature does do down I believe the thermostat is to blame. Please confirm. Thanks |
Re: 2002 pontiac montana coolant temp
I believe you're right.
Circulation isn't happening.
The problem with doing nothing is not knowing when you're finished. |
Are you sure it's not the water pump? It sounds like the water pump vanes may be corroded off and it's not circulating coolant until it's at a very high rpm.
I was curious, has the issue been resolved?
