Old 02-06-2010, 10:21 AM
jtaylor6719 jtaylor6719 is offline
Question swaping an engine diff transmissions
i was told i would be able to put in an engine that came out of an automatic into my standard, all i have to do is change the flywheel and a couple sensors. is this true?
Old 02-06-2010, 11:55 AM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: swaping an engine diff transmissions
If it's the same engine design, all you should have to do is swap the flywheel for your flexplate. What sensors did they say you had to change?
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 02-07-2010, 12:21 AM
they said speed sensor but i guess my flywheel is good but i need a new throwout bearing which is hard to find seperately from a clutch set. i guess it would be good to do the clutch too... it is ten years old... and the person who drives it is a bit rough with it. maybe change out the starter since she does leave her key turned for a bit longer than most. what would you recommend?
Old 02-07-2010, 10:14 PM
J-Ri's Avatar
If I were you I would buy the clutch set in case you need it. After you get the engine separated from the trans, take a look at the old clutch and replace it if it's very worn. I wouldn't replace the starter, it's easy enough to do later if it would fail... I don't know if keeping the starter engaged a bit longer than normal would do any real damage anyway.
Old 02-07-2010, 11:54 PM
thank you for all your advice, one last question. what would you pay for a basic 2.2 engine with 100k on it? they already have the engine pulled but im not sure what to ask. he wants $350 but i think ill just offer $275. what do you think? the link to it is here
http://denver.craigslist.org/pts/1582018000.html
