Old 02-05-2010, 11:08 PM
Cannon84 Cannon84 is offline
Angry 2000 Grand Prix GT Tire Problems
All, I replaced all four struts, got a four wheel alignment, and got a new set of tires mounted and balance a few months ago. I drive 130 miles round trip to work 5 days a week. I rotate the tires between 6 and 7 thousand miles. My tires are begining to wear uneven on the inside. I had the alignment rechecked to see if that was the probem; it wasn't. I had the front drivers side hub replaced because it was bad. I have no clue what to check next. If anyone has any recommendations I higly appreciate the information. Thanks in advance.
Old 02-06-2010, 12:18 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: 2000 Grand Prix GT Tire Problems
If the hub was very bad, it could cause unever tire wear. I had my car alightned, then found out my hub was bad, replaced it, and now the alignment is off because the car was aligned with a bad hub.
If the hub was just recently replaced, I would rotate again, and check the tires with a good hub on there after a few thousand.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 02-06-2010, 11:17 AM
BNaylor's Avatar
BNaylor BNaylor is offline
What brand tires?
Get the camber specs and post. They may be borderline but passing alignment. Also, the toe-in specs.
Timeslip 08/12/06
AF Community Guidelines
Old 02-06-2010, 06:52 PM
rickisrad rickisrad is offline
definately get the before and after specs. Unfortunately, I have seen a lot of times the tech said they did a 4-wheel but only set toe, either because the rear nuts did not move freely or they were too lazy to do it. The bearing should have been caught and suggested repair prior to the alignment by any competent technician. You are definately having some sort of camber issue. Did you put in camber kits, or were the struts auged out? If neither of these were done the place doing the alignment is probably just setting toe, which will leave camber possibly out of or close to specs.
2004 GRAND PRIX GTP COMP G. VIN 4 :
OVERKILL CUSTOM PCM, WIZAIR CAI, ZZP TRAILING ARMS, W BODY STORE LATERAL ARMS, ALL POLY/SOLID MOUNTS, STB F&R, ZZP RACE TRANS, ALT REWIRE & VOLTAGE BSTR, 180 STAT, NGK TR6, MPS with 3.4 PULLEY, PACESETTER HEADERS, 1.8 ROLLER ROCKERS, FP REWIRE,ZZP COILS/WIRES, TB SPACER, D&S ROTORS, INTERCEPTOR SCAN GAUGE, CUSTOM STAINLESS 2.5 INCH CAT BACK EXHAUST.
2004 Honda Odyssey EX-L
Old 02-06-2010, 06:55 PM
.........also check your control arm bushings.
Old 02-06-2010, 07:28 PM
grandprixgtx00's Avatar
grandprixgtx00 grandprixgtx00 is offline
Send a message via AIM to grandprixgtx00
i was just going to suggest the lower control arm bushings.
Old 02-08-2010, 08:15 PM
Thanks all, I will take all the advice and get my car back into the dealer.
