88 Camaro Intake Manifold Gasket
I recently bought an 88 camaro iroc, but it has an intake manifold gasket. I was wondering if this is a hard fix, and basically how to go about doing it if not. Thanks
Re: 88 Camaro Intake Manifold Gasket
Knowledge can be communicated, but not wisdom! ![]() ![]() |
It has a coolant leak, back by the firewall. It's not too bad, but it's something that i assume needs to be fixed.
nooooooooooooooooooooo it is a bad thing cause if the coolant is leaking towards the inside it might end in one of the pistons. and as we know water is hard to compress so it might cause a piston rod to bend making it worst then just a change of a gasket. now i don't know if the firing order is number one in the back (meaning on the firewall) if they coolant is leaking to that piston it is somthing serious cause if you crank it cold chances is that it going to bend the rod
opcorn:
