Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 02-05-2010, 10:59 AM
Godofwarmike's Avatar
Godofwarmike Godofwarmike is offline
Question PCM question
This summer I plan on turning my AT neon into a MT neon. I have all the parts to convert it except a MT pcm. Can I use the AT pcm? I would just go to a junk yard and grab a MT pcm but I need the VIN to match.
I know I would have to do something about the park neutral safety switch but would the torque converter lockup solenoid cause the check engine light to trip?
Is there any other issues I would have to deal with? If it is possible to use the AT pcm that is.
1999 Purple Plymouth Neon SOHC Automatic
Bought Feb 2009 For $700
125,000 miles
Maybe the world record for car with most hidden zip ties
Old 02-06-2010, 10:06 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: PCM question
You can use the ATX PCM, you will have the lower rev limiter. The VIN# isn't stamped anywhere on the PCM either, so I don't see why you couldn't just swap in an MTX PCM.
You will also have a CEL for the Torque Converter solenoid not being active as you won't have one any longer.
2003 Dodge SRT-4
Old 02-07-2010, 05:00 AM
Question Re: PCM question
I would just swap in a MTX PCM but isnt the VIN stored in the PCM so when I go for NYS Inspection and they put it on the computer it will show its the wrong PCM and it will fail?
125,000 miles
Old 02-07-2010, 09:30 PM
Re: PCM question
The first gen neon's PCM does not store the VIN# at all. I think some second gen's do, maybe 02 and up.
2003 Dodge SRT-4
Old 02-07-2010, 10:10 PM
alright so as long as I find a 1999 SOHC MTX PCM It should plug right in straight forward?
125,000 miles
Old 02-08-2010, 07:08 AM
Re: PCM question
97-99 SOHC MTX PCM will do you just fine. All plug and play.
2003 Dodge SRT-4
Old 02-08-2010, 12:24 PM
Talking Re: PCM question
Alright sweet thanks
125,000 miles
