Old 02-04-2010, 10:42 PM
Sledge12 Sledge12 is offline
Switch Housing
I have a 1990 Chev Cav z24 that the headlight "switch housing" (that's what GMPartsDirect.com calls it) is broken. I have checked my local junk yards and dealerships and no one has this part. Can someone point me in the right direction to get a replacement for this part. Just so you understand which part I am talking about go to www.gmpartsdirect.com. Click on catalog. Agree to their policy. Put in the year "1990", Make "Chevy" and then model "Cavalier". Then on the new screen click on "instument panel" then "instrument panel" again then on "bezel". You should get a picture with all the parts of the dash. The number I am talking about is 10 "Switch Housing" Sorry for being so lengthy but I could not copy the URL so it would work properly to paste it into this post. Please if you can help I would be very appreciative. Thanks so much.
Old 02-06-2010, 12:10 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Switch Housing
Try e-mailing customer service... otherwise you're probably out of luck, most of these in salvage yards have been picked clean and crushed. Is yours good enough that you can epoxy it back together?
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 03-07-2010, 02:26 PM
CraigZerch CraigZerch is offline
Re: Switch Housing
You could try ebay.
