Old 02-04-2010, 04:38 PM
Yucca Yucca is offline
Wierd dashbard light behavior - 2002
Starting this morning, every time I put my car into gear (not when I turn it on, when I take it out of park) the light for the "always-on headlights" flashes on and off about 6 times then the service light comes on.
I haven't noticed any change in how the car works, and but it only started happening today.
Any thoughts?
Old 02-04-2010, 07:13 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Wierd dashbard light behavior - 2002
That's the indicator for the DRLs, the flashing indicates a bulb is burnt out or a wire is open. Try replacing the bulbs (replacing the pair is strongly suggested for even light, plus since they're used for the exact same time as the other they usually burn out at about the same time.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
