Old 02-04-2010, 12:24 PM
mikeyDep mikeyDep is offline
94 jimmy egr valve code
hey, got a 94 w/vortec, got a 32 when reading the code...'cause the light came on...
so i figured i'd need to replace the egr soon...
today, it barely wants to run...very rough idle, hard brake 'til i'm moving a little....
what do i do????
should i clean the original first? and see if that helps?
any help is greatly appreciated.
Old 02-04-2010, 01:06 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 94 jimmy egr valve code
what do i do????
Code 32 goes to about 4 different EGR valves.
Which one do you have?
Vacuum or electronic?
Rough idle and hard brake points to egr valve stuck open or carbon ball under plunger.
I would remove it and clean plunger and check plunger and egr valve for sticking open.
MT
Old 02-04-2010, 09:45 PM
tom3 tom3 is offline
I believe the 94 with the Vortec would have the electric valve. Take it off and check for a chunk of carbon holding the pintle off the seat. If so just clean it out. While the valve is off you can also start the engine and let the exh. pressure blow out any loose particles. It will rev up a bit and make some noise so don't worry about it.
Old 02-05-2010, 06:58 AM
i believe it's the electric one..gonna dig it out today and see what condition it's in...hope i don't have to buy a new one, they're kinda pricey.
thanks for you input, will post my results later today...
hope i get it done before the snow comes!
