Old 02-04-2010, 01:38 AM
ptrkintx ptrkintx is offline
'98 Sunfire turn signals
Neither of my turn signals is working right. They only flash once or twice, if at all, or sometimes more. This is common to both sides. My hazard lights are working fine which would seem to eliminate the flasher. Could it be a bad switch or something more sinister? Any help would be appreciated.
Old 02-04-2010, 07:15 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: '98 Sunfire turn signals
The hazard and turn signal flashers are two separate pieces. I'm not 100% sure where the turn signal one is on a '98, but the older ones are clipped to a panel under the drivers side dashboard.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 02-04-2010, 07:43 PM
turn signal and hazard flashers have same p/n, and as I see it the turn signal-hazard-headlight switch is one unit.
