Old 02-03-2010, 05:59 PM
dblackmer dblackmer is offline
94 jimmy 4x4 4.3 vortec running rough/backfire
I have a 94 jimmy 4.3 vortec. Changed plugs, wires, egr, oil and filters. adjusted timing to tdc. Still running rough and occassionally pops/backfires from under hood it sounds like. I am planning on changing the cap and rotor tommorrow. Any other ideas????
Old 02-03-2010, 07:25 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 94 jimmy 4x4 4.3 vortec running rough/backfire
Did you use the bypass mode to set timing?
Make sure plug wires is not crossed.
Let us know how it goes.
MT
Old 02-03-2010, 07:31 PM
what is the bypass mode?
Old 02-04-2010, 09:43 AM
MT-2500's Avatar
AF - Advisor
They have a bypass wire/connector on ign system that you have to unplug to put it in base time mode.
May be behind glove box or under heater core on inside engine compartment on firewall area.
Always put it in bypass/base time mode to set timing.
MT
Old 02-04-2010, 04:14 PM
Thanks for the info. I changed the rotor, cap, feul press. reg and plenum gasket and then retimed using your advise and runs excellent now.
Old 02-04-2010, 06:17 PM
MT-2500's Avatar
AF - Advisor
You are welcome and thanks for posting back how it went.
Good Luck
MT
