Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Old 02-03-2010, 02:50 PM
zombe1961 zombe1961 is offline
Front end very noisy 2002 Bravada
How to tell if your srutts are bad. There is a realy loud squeaky noist wene turning on bumps it sounds like the shock is traveling up and down.
Old 02-22-2010, 09:11 PM
karlmarx karlmarx is offline
Re: Front end very noisy 2002 Bravada
Interesting, I was just about to ask about a similar problem. Does yours make a bad "kachunk" sound as it goes over potholes? And it only happens in the front, correct? I've had this diagnosed as a problem with the differential or with the drive axle, but none of those supposed fixes worked. I've even had the CV boot assembly replaced 3 times in the last year. I've spent a lot of money, and the problem hasn't gone away. I hope that it is the struts since that's a relatively inexpensive fix.
Let me know what you find out.
Old 11-05-2014, 05:17 AM
beir's Avatar
beir beir is offline
old dog learnin new trick
Check your control arm bushings & ball joints...since they move over every bump in road they will squeak. when worn out or dry
