Go Back   Automotive Forums Car Chat > Jeep > Liberty
Old 02-03-2010, 12:56 PM
datslegne datslegne is offline
Tire Sensor Not Reading Since Repairs
2006 Jeep Liberty had calipers and rotors replaced and other brake work on the front end.
Since the repairs, the left front tire sensor is not working. It shows just dashes for tire information and a warning light on my dash.
The shop that did the repairs has no clue what happened and do not know what to do to fix this.
Any ideas? And... did the shop damage the sensor during the repairs - or all just a coincidence?
Old 02-03-2010, 02:38 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: Tire Sensor Not Reading Since Repairs
They likely damaged the sensor when they were doing the work. but it could be another issue. I would make sure it's documented with the shop, then have the system checked at the stealership. If the sensor is damaged, then bill the brake shop for the work to have it repaired.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 08-14-2010, 09:30 PM
mojodojo2k's Avatar
mojodojo2k mojodojo2k is offline
Send a message via Yahoo to mojodojo2k
The sensor is inside the rim with a rubber stem...so it's impossible to have damaged the sensor unless the tire was removed from the rim. You can bend that rubber stem back & forth all day and nothing will happen (when mounted on the rim). I think it's just coincidence....doing brake work should not interfere with the pressure system whatsoever. I would have taken the Jeep back and asked to have the tired unmounted to inspect the non-working sensor. The majority of tire sensors stop working when they are damaged.....if the sensor in your Jeep WAS damaged then you will see that upon the inspection of it!
