Old 02-03-2010, 09:24 AM
royaldjasperdd royaldjasperdd is offline
Fuel issues
My son's 1996 s10 had an intermitten fuel issue- previously tapping the tank or shaking the big connector near the firewall a little would "heal" it for a while. Then it got worse... Replaced the fuel pump, wired around the slightly corroded connector, checked the relays and it is still the same. Especially if you let it die ( new driver on a standard!) you are not going anywhere without 10-15 minutes of fiddling around and then its only 50/50. Any ideas?
Old 02-03-2010, 02:45 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Fuel issues
What engine?
Did you use the delphi fuel pump or junk aftermarket?
Did the fuel pump come with a new wiring connector?
Does engine crank over good?
Does it get spark to all plugs when no start?
Check fuel pressure when no start?
Does the fuel pump get 12 volts when no start?
Is tank ground good?
Can you hear key on 2 second fuel pump prime up?
Does fuel pump run engine cranking?
Post back fuel pump pressure readings and what engine you have.
MT
Old 02-03-2010, 03:04 PM
Re: Fuel issues
Thanks MT for the quick response- here comes a long answer
4 cyl engine 2.2l, bought a rebuild kit cheap- because a delphi is the 1st dead one and bought a used delphi from salvage yard- it was doa so hooked the old one back up and it sqirted 25 ft, so replaced worked 2-3 months before permanent death.
When it won't start there is no power to the pump- nor at the firewall connector. (kept the old delphi incase it wasn't the problem but the kit was only $24)
Ground is good and tight at the pump
I really thought the pump was at issue because for a while a little bang on the tank got it going, other times only fooling with the connector/relays will.
I noticed that while using a test light on the connector that sometimes worked so I jumpered around the connector- worked 3 times and now nothing.
Previous owner had similiar issues but did not inform me- 1500 dollar truck!
Next I'm going to try jumping around the relay and then the oil P switch unless you have a better idea- Here in NW arkansas the good pumps were around 400 at AZ and Oreilly- so I felt compelled to go cheap even if it was temp. relief. WHEN it runs it runs like as good as these trucks can. Pulls small boats/jetski great.
Old 02-03-2010, 03:39 PM
MT-2500's Avatar
AF - Advisor
Re: Fuel issues
I noticed that while using a test light on the connector that sometimes worked so I jumper ed around the connector- worked 3 times and now nothing.
At the fuel pump relay check for good 12 volts on orange wire.
There is a red prime wire/connector there you can jump fuel pump.
Or jumper 12 volts to fuel pump feed gray wire.
With key on 2 second prime up or engine cranking you should have 12 volts on gray fuel pump feed wire and the prime up connector.
Also confirm good spark to plugs when cranking.
No spark will cause fuel pump not to run on engine cranking.
Check them wires you redone real good.
With fuel pump jumped see of it runs and has 41/47 lbs of fuel pressure.
MT
Old 02-03-2010, 03:46 PM
MT-2500's Avatar
AF - Advisor
Re: Fuel issues
The oil pressure only feeds power to gray fuel pump feed wire oil pump after engine oil pressure is up.
But only if fuel pump relay fails does the oil pressur switch run fuel pump.
CONFIRM GOOD FUEL PRESSURE AND GOOD SPARK WHEN NO START.
And make sure relay is getting 12 volts on power feed wire to it.
MT
Old 02-03-2010, 04:10 PM
Re: Fuel issues
I will not be able to try this until SAt but will let you know what happens- thanks again
Old 02-03-2010, 04:36 PM
MT-2500's Avatar
AF - Advisor
Re: Fuel issues
Good luck.
MT
Old 02-15-2010, 07:50 AM
Re: Fuel issues
Ok- I tracked everything and all seemed to check out as best I could tell, but I noticed the relays in the glovebox were pretty loose- I took them and splayed the legs on each so that they were pretty hard to put back in. I also rewired the big connector on the firewall- eureka! So far in limited usage no more problems!
Old 02-15-2010, 06:31 PM
Darren509 Darren509 is offline
Re: Fuel issues
F.Y.I. In case you ever do need a pump in the furure, try looking at autopartswarehouse.com I believe they are about 260...good luck.
Old 02-15-2010, 06:42 PM
Rick Norwood's Avatar
Rick Norwood Rick Norwood is offline
Big Tall Dumb Ass
Re: Fuel issues
If they are not AC-Delco Delphi pumps you're wasting your money!
"If everyone is thinking alike, then no one is thinking". - Gen. George S. Patton Jr.
Old 02-15-2010, 08:29 PM
Re: Fuel issues
null
AutoMD
Easy to use Q&A diagnostic tool
Get fair and objective estimates for repairs
Search over 400,000 repair shops
Over 100,000 easy to use how-to guides
Get Free Auto Repair Advice
Home > Delphi Fuel Pump
Your selected vehicle: 1997 GMC Jimmy SLT 6 Cyl 4.3L
advertisement
Recommended Accessories
Kool Vue Mirror
List price: $34.57
Our price: $29.30
Replacement Bumper
List price: $125.24
Our price: $102.67
Replacement Headlight
List price: $223.10
Our price: $95.16
Replacement Tail Light
List price: $60.95
Our price: $51.65
Based on manufacturer’s specs, this part is an exact fit for:
To display products for a different vehicle, click here.
Delphi Fuel Pump - With Fuel Pump
Part number: W0133-1598970
Manufacturer number: W0133-1598970
zoom
Be the first to write a review.
Availability: In stock
List Price:
$585.66
Our Price:
$282.95
You Save:
$302.71
QTY:
Type: With Fuel Pump
Warranty: 12-month or 12,000-mile warranty
Condition: New
Fit note: (Includes Fuel Level Sender Unit)
Old 02-15-2010, 08:30 PM
Re: Fuel issues
My copy and paste method diddnt work that good, but yes, its a Delphi. For 282.
