Old 02-03-2010, 09:11 AM
H22_DB2 H22_DB2 is offline
Car bogging(no power) upon take off????
So i was at a stoplight this morning and the light was red when the light turned green i toke off and the car did nothing like bogged out (had no power) then went back to normal i noticed this every once in a while,what could be the cause? and where to start off looking and diagnosing the problem? it did it about 3 months ago and i ran some fuel injector cleaner through it for a about 3 tanks of gas. well it stopped doing it but im not sure if it was because of the the cleaner or just stopped caues it only does it once and a while,i would like to fix this problem if anyone has any advice on it or where to start checking,I think it is something fuel related or a sensor but im hoping for some other opinions,thanks
Old 02-03-2010, 11:00 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: Car bogging(no power) upon take off????
What year?
Old 02-04-2010, 07:37 AM
1999 base model
Old 02-04-2010, 08:10 AM
danielsatur danielsatur is offline
You need plenty of good Air, fuel, exhaust, and ignition timing for horse power.
If missing any one of the four will cause lost hp.
1) Air- New Air filter, clean MAF, IACT, and throttle body.
2) Fuel - New fuel filter, and fuel pressure tested.
3) Exhaust - Have your catalytic converter Tested, a plugged, or broken cat can choke an engine out.
Old 02-04-2010, 08:23 AM
ZiggyPA ZiggyPA is offline
I am thinking it would be more of an electronical or ignition problem since it only does it once in a while...
