Old 04-11-2003, 11:46 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
Question Throttle Angle/Position Sensor
The sensor on the back of the throtthe body, is that the throttle angle sensor or the throttle position sensor? Are they the same thing? Anyone got any pictures of either or both so I know what I need to go get from the honda dealership tomorrow (mines broken)? Thanks
Old 04-11-2003, 11:48 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
well if its in the back and its alittle black clip, thats the tps
Team Lonely Drivers
Old 04-11-2003, 11:49 PM
Oh yea, also does anyone have one that they could send me for real cheap and fast?
Old 04-12-2003, 09:21 AM
*bump*
Old 04-12-2003, 11:31 AM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
If you bust your TPS, I thought you had to buy a whole new throttle-body... ? Mines busted on my D16Y8, so if I don't have to replace the whole TB, I would much rather just replace the TPS.
Old 04-12-2003, 11:54 AM
kris's Avatar
kris kris is offline
Off playing with fire.
Nope, you can just replace your TPS sensor. They have breaking screws in them, so you cannot just undo the screw, and away you go. The best way I have found to get them off, is take a grinder to the head, then pop the TPS off. I may have one sitting arround, and I know there are plenty at the boneyard here. But I wont be making a trip there until tuesday.
Old 04-12-2003, 04:38 PM
RedRacerCivic's Avatar
RedRacerCivic RedRacerCivic is offline
Send a message via AIM to RedRacerCivic
hey 91civichatch, you will need to find a TPS off a DX motor cause an Si TPS or any MPFI TPS will not work on your DX throttle body, Si and DX TPS turn opposite.
-1991 Civic Si (Sold)
-1990 Accord EX(Sold)
-2000 Civic Hatch
-1998 Lexus SC300
Click here to see my Shoe!
Old 04-12-2003, 04:40 PM
Thats only if you go to a Honda dealership, they do not sell TPS by themselves, you have to buy the throttle body as a whole to buy one and they are alot of money. Best way is to find one off a MPFI t-body and do the grinding thing, thats what I did..
-2000 Civic Hatch
-1998 Lexus SC300
Old 04-12-2003, 11:04 PM
Its for my ZC that im putting in. Anyways though, you can switch the 2 wires going into the DX one, it will turn the opposite way (atleast thats what ive been told). Actually, does this mean that I can use my DX sensor and just switch the wires or does it have to be one from a MPFI?
Kris, have you found any laying around? If you could find one at the junkyard, how long do you think it would take for one to get mailed to NY?
Old 04-13-2003, 01:19 AM
Not sure if putting the DX one on the ZC t-body will work, I was in the same situation as you, I had a good working DX TPS and tried to put in on my Si T-body......did not fit right, trying to bolt it on required turning the TPS wheel so that it will fit in the t-body, and it turned opposite, it just wont work.
-2000 Civic Hatch
-1998 Lexus SC300
Old 04-14-2003, 10:56 AM
kris's Avatar
Hitting the junkyard up tomorrow, if I can grab some, I could get it mailed out ASAP.
Old 04-14-2003, 12:59 PM
turbcivic's Avatar
turbcivic turbcivic is offline
They are called shear bolts, the head shears off when tightned enough, same as on the igntion switch/lock. Just put the TB in a vise and take a chisel or old flathead screw driver and hold it at an angle to the head of the bolt. Beat it into the bolt to turn it counterclockwise. These things are a bitch to get off.
2007 dodge ram hemi sport-the tow/dd
1993 Civic HB-h22 with type s pistons, 125 shot, and some other goodies
1989 CRX(in the works)-h2b plus maybe some spray, or some boost
Old 04-14-2003, 09:38 PM
Kakarrott Kakarrott is offline
All i did to get my tp sensor off my d16a6 si was took a dremel with cutting disk made a slash for a flat srew driver to fit and unscrew remove easy and remember all, remove that damn sensor before a swap i broke mines of my B16A and the throttle body at the dealer that the only way they sell bastards is 700usd ,junyard for b16a usdm if 150usd
In SO CALI
Crankshaft position sensor GregGP Grand Prix 1 03-25-2010 04:33 PM
Pontiac GA Cam position sensor LOCATION ? cigars99 Grand AM 6 07-11-2009 10:30 AM
1998 Taurus Crankshaft Angle Sensor / Synchro / Cam Position Sensor rjs985 Taurus | Taurus Wagon 9 02-12-2007 04:46 PM
Where is the crank angle position sensor ? Chrismarinelli Integra 1 05-10-2005 08:48 AM
Throttle Position Sensor/Throttle Switch Adjustment westsidex Metro 3 05-24-2004 06:17 PM
