Go Back   Automotive Forums Car Chat > BMW > 7 Series
Old 02-02-2010, 02:39 PM
Rh1717jr Rh1717jr is offline
740il 2001
I have a clicking sound when I crank the car I think it might be tenioners please advise if I am right?
Old 02-04-2010, 08:58 AM
Bear Bear is offline
Re: 740il 2001
If you emailed me about the light on shifter console staying on, it does for about 15 minutes. As to current draw, 50 milliamps is the maximum accepttible, if yu haven't done this, remove negative battery cable and hook a multi meter up between the cable and the battery negative post, then, start pulling and replacing fuses until the current draw is within limits and that is your bad circuit. Hope this helps, also another good forum is at roadfly.com.
