Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 02-02-2010, 11:48 AM
Captain Ahab Captain Ahab is offline
Driveaxle retaining nut
Hey I was wondering what size the driveaxle retaining nut is on a '97-'03 Malibu or '03-'04 Classic.
Have a wheel bearing starting to go bad (I think).
Any help is greatly appreciated.
Old 02-07-2010, 04:02 PM
AD2BU AD2BU is offline
Re: Driveaxle retaining nut
I don't remember the exact size, but when I replaced the bearing/hub assembly on my 98, I went to AutoZone and they had a replacement axle in stock and we used that to get the right size socket. Rented the socket and puller from them for $0. Remember to loosen the retaining nut with the vehicle on the ground (with a big breaker bar). You won't be able to loosen it once you have the vehicle up - even with an impact wrench. Also, the torque is like 175 ft-lbs (or something pretty high). I just went to the max on my torque wrench and then took another 1/8 turn with a breaker/cheater bar and called it good.
Good luck with the repair. The bolts that hold the hub on the back side are difficult to get a socket/torque wrench on.
Old 02-07-2010, 04:49 PM
maxwedge maxwedge is offline
A990 racer
36mm nut and 275 is way too much torque, should be about 150 or on some bearings look for the specs in the box.
Old 02-07-2010, 08:36 PM
Wow - bad typo on my part. I meant 175.
Old 02-09-2010, 10:41 PM
manicmechanix manicmechanix is offline
What's funny is the original specs was something really high like 284 lb ft and I think it was causing the bearing to go out. GM issued a TSB with a new torque spec of about 175 ft lbs and a new nut.
