Go Back   Automotive Forums Car Chat > Buick > Regal
Old 02-02-2010, 06:21 AM
TZ250 TZ250 is offline
Fuse for Third Brake Light
Does anyone know where the fuse is for the third brake light? I'm assuming, for now, that a fuse is bad because both bulbs won't light.
TIA!
Old 02-02-2010, 07:13 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Fuse for Third Brake Light
What year Regal is this?
For 1997 and up there is no fuse for the third brake light.
Timeslip 08/12/06
AF Community Guidelines
Old 02-15-2010, 06:54 PM
It's a 2002. I've looked and looked for the fuse. It's possible that both bulbs went out at the same time, but I assumed that a fuse would cause that problem. I couldn't get the socket out to test for voltage.
My next step will be to get the bulbs out and check them. Is there a LED equivalent to the 3155?
Old 02-16-2010, 06:33 AM
BNaylor's Avatar
Very possible both lamps are burnt out. I've had the issue in our ''99 Regal LS.
Timeslip 08/12/06
Old 03-03-2010, 07:44 PM
How do I get the bulbs out? I tried twisting clockwise and counterclockwise, pushing up and pulling down. The amp blocks the drivers side bulb, but it will be easy to remove.
I don't want to break the housing. Is there a trick to this?
Old 03-03-2010, 07:51 PM
gjwickline gjwickline is offline
there is a seperate brake light switch on the brake pedal for third brake light. check for proper operation there,
Old 03-03-2010, 09:31 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Yes, Click Here
Old 03-07-2010, 10:57 AM
BNaylor's Avatar
1/4 turn counterclockwise.
Timeslip 08/12/06
Old 03-24-2010, 11:16 PM
phuongtim39 phuongtim39 is offline
I accept with information: The amp blocks the drivers side bulb, but it will be easy to remove.
Argentina adventure tours
