Old 02-02-2010, 06:09 AM
Beakster's Avatar
Beakster Beakster is offline
What do you use to polish your models?
I've used micro mesh before and it works well, now I'm trying the Tamiya polishing compounds and this works well for me, especially when getting into small recesses.
Is there a cheaper or better compound to use?
What are your preferences?
Current W.I.P - Tamiya 1/12 Yamaha YZR500
Old 02-02-2010, 09:25 AM
stevenoble's Avatar
Re: What do you use to polish your models?
I use Tamiya compound as well, but also Finisher's compounds are very good and Mr Hobby liquid compounds are pretty good too.
Steve Noble
Old 02-02-2010, 09:37 AM
KevHw's Avatar
KevHw KevHw is offline
I started out with MicroMesh which had a great first impression but then moved onto Tamiya compounds coupled with Meguiar's Scratch X and Tamiya wax. I only go up to about 3600/4000 mesh before polishing my way up through Tamiya coarse to fine, then scratch X and finally wax. I think Scratch X is pretty good value for money so, more economical.
Old 02-02-2010, 12:22 PM
cjsbosox's Avatar
cjsbosox cjsbosox is offline
I use 3M plastic cleaner and plastic polish. They work great.
Old 02-03-2010, 03:41 PM
Didymus Didymus is offline
Tamiya. Many cheaper, none better. I use all three, in sequence. Tamiya Finish comes very close to wax, IMO. Everything else I've tried leaves a fine scratch pattern that you can see in the right (wrong?) light.
D D M S
Old 02-03-2010, 09:05 PM
Dingo1 Dingo1 is offline
I roll dip my cars in floor polish and do it slowly just like they did in the early days od the motor industry, then hang the body to dry in the laundry to dry.
Dingo
Old 02-04-2010, 04:22 AM
skiff's Avatar
skiff skiff is offline
I use Farecla compounds. Why? Because I happen to have some lying around in the house.
For sanding I use Mirka Abralon (comes in 360, 500, 1000, 2000, 3000, 4000 grit). Cheaper then the "modelling stuff" and very probably the same. (Mirka makes the stuff, Tamiya repackages it)
www.bugattibuilder.com Your Bugatti resource. Types, scale models, books, WIKI, links.
Bugatti forum. Discuss Bugattis here!
Bugatti photo. NEW !!! Largest online Bugatti photo archive (11000 photos and counting). You can contribute too!
