Old 02-02-2010, 02:05 AM
felix the cat felix the cat is offline
95 safari problems
I have a 95 sarari 4.3L W cmfi
Started to run rough,and black exhaust, so i thought i would try to fix myself.
I have changed Oxy sencer,Map sencer,EGR valve,air cleaner,pcv,
plugs,wires,distributer cap,rotor,and coil.
When i changed plugs,all on drivers side 1-3-5 were light brown ash color.
On the pass side 2-4-6 were all dry black soot .
Still runs badly,black exhaust ,and also can smell gas.
I was told it may be the spider injector.
What i can't understand is why all plugs on drivers side are good ,and all on pass side are dry black soot ?
I am going to take a compression on all cyl today,and will post back.
Old 02-02-2010, 05:16 PM
Re: 95 safari problems
OK i took compression on pass side where plugs were all soot .
got 150/142/142.
removed upper manifold, and found gas everywhere.
Now will replace spider and will repost outcome.
Old 02-02-2010, 08:44 PM
old_master's Avatar
Advisor/Moderator
The left bank plugs are burning fine indicating the fuel pressure and return lines are not leaking. The passenger side all soot, most likely VERY noticeable on #3 plug, indicates the fuel pressure regulator is leaking.
Dorman, (part #55163) makes a replacement "nut kit" available at most auto parts stores. The fuel pressure regulator is also available at most auto parts stores. The entire spider assembly should come with everything. Make sure it has the pressure and return lines, if not, do yourself a favor and replace them too.
You have to know how it works,
to figure out why it doesn't.
Old 02-06-2010, 03:54 AM
Had good compression 150/142/142 on sooty side.
Replaced spider with remanufacture oem ,and engine is now smoooth.
never ran as good !
Old 02-06-2010, 02:18 PM
old_master's Avatar
Advisor/Moderator
Glad you got her fixed, thanks for posting back.
