2002 Astro died and won't start
I have a 2002 Astro AWD X code engine. I was driving home a little over a week ago and it just quit a block and a half from the house. I tried to restart it but, it wouldn't start. I get it home the next day, pull the doghouse, and check for spark(it is the easiest and less expensive thing to do first). I determined that it had spark and would run on starting fluid so I loaded it on the trailer to take to my shop. I cycled the key a few times to listen for the fuel pump. Nothing! I cycled the key a few more times to check the relay and fuses. Relay and fuses are Ok. So begins the Joyous task of dropping the tank to replace the fuel pump. I bought a new DELPHI pump thru my buddy who is a Napa dealer for $254. It was originally $331 but, he gave it to me for his price. All I can say is it is a real pain in the a--. I had to cut the hose for the filler neck and replace it due to the fact that it wouldn't come off. It is 1 1/4" on one end and 1" on the other. I replaced it with 1 1/4" and it works just fine.
I hit the key and it fired right up without any problems. I hope this helps somebody else.
AB
Never the Coyote. Always the Roadrunner.
