Old 02-01-2010, 10:05 PM
dnmir54 dnmir54 is offline
Smile cleaning MAF/ oxygen Sensors
there are 3 oxygen sensors on her S10, can they be cleaned ? what is best way to clean the Mass air flow sensor and do you know what other years will fit her 1996 S10
how do you test the sensor to see if it works correctly?
thanks again for your help
( finnally something showed for codes)
Old 02-02-2010, 03:01 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: cleaning MAF/ oxygen Sensors
What was the code no.?
The only to test them is with a lab scope or good engine capable scanner.
02 sensors can not be cleaned.
Just replace if bad.
Maf sensor can be cleaned with electrical or MAF sensor or carb spray type cleaner.
Just spray resistor and let dry and spray again a couple of times.
Cleaning does it some times and sometimes they have to be repaced to.
For other years that fit check the parts place parts book or salvage yard inter change book.
MT
