Old 02-01-2010, 09:47 PM
shanes76 shanes76 is offline
cam ?
how would you know if your cam was going out? 4.3 Vortec vin "W" 94 Jimmy
Old 02-02-2010, 12:31 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: cam ?
Check the push rod lifter travel on all lobes to start with.
What makes you think it might be bad/going out?
MT
Old 02-02-2010, 06:08 PM
Re: cam ?
I was just kinda wandering MT, kinda learning, I like to know how things work, what goes wrong when something is bad. I got trouble with my Jimmy(which Im doing the fuel pressure test this weekend) but someone said something about the cam
Old 02-02-2010, 06:52 PM
MT-2500's Avatar
AF - Advisor
Re: cam ?
Bad cam lobes leads to engine miss and lifter noise.
But cam lobes do not go bad very often anymore.
Describe your problems and give codes if any.
Any missing under load?
Any check or flashing check engine lights?
How many miles on it?
Have you done a good tune up?
Good AC Delco plugs?
Post back your fuel pressure readings.
MT
