Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 02-01-2010, 08:19 AM
Cbpcop's Avatar
Cbpcop Cbpcop is offline
Beyond Vibration
Not so simple as an unbalanced tire. Left front wheel/tire starts shaking at about 35 mph, worsens with increase in speed up to 52 mph then quits shaking. Some residual (though minor) vibration after that. Had tire balanced already at a good shop so I don't think that's it.
Struts are due for replacement - could that be part of the problem? I've had the thing on a lift and don't see anything indicative of a ball joint or an a-frame bushing, BUT, is it possible/probable that my problem is one or more of the latter problems combined beyond the tire issue? (and yes, I do believe it's possible for the problem to still rest with the tire - they're BF Goodrich All Terrain TA's - 15x10.5s and I've never had one bit of trouble with them - have approximately 35-40,000 miles on them.
Thoughts?.....................................:run around:
Old 02-04-2010, 01:15 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: Beyond Vibration
Worn ball joints or struts can magnify the shaking by not dampening the shake through the "resonance" speeds. If your truck has a steering damper shock that is old it can also cause shaking...also check the tie rod ball joints. Check a repair manual for the procedure for testing the ball joints.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 02-10-2010, 12:51 AM
OzzyO's Avatar
OzzyO OzzyO is offline
Send a message via MSN to OzzyO Send a message via Yahoo to OzzyO
Was your drive shaft removed at any time ?? If it wasn't reinstalled right it could be not balanced. I had my rear drive shaft off and on 3 times before I got it right, you will notice a square slab of steel on your drive shaft and if the drive shaft is not on as it was from the factory it will throw it out of balance. I own a 94 4runner for over 10 yrs now been there done that kinda thing, if nothing else is working for you give it a try, it worked for me, although I wasn't the one who originally took the drive shaft off lol. As long as it fixes it thats what counts.
