Go Back   Automotive Forums Car Chat > Ford > E Series
E Series Forum covers questions and discussions regarding Ford E-150, Ford E-250, Ford E-350, and Ford E-450.
Old 02-01-2010, 07:43 AM
cmangle cmangle is offline
1992 Ford E-250 trans replacement Throttle Valve cable
I am replacing the AOD tranny in my 1992 Ford E-250 conv. van.
I am hearing horror stories about making sure the throttle valve cable is adjusted correctly or I could burn up the replaced tranny.
Is this something I can do, I work as a mechanic in general and have broad mechanic skills wit the exception of tear down/rebuild tranny experience.
"IS THERE" a major problem with this "throttle Valve" cable that I should be aware of and can I re-install my used trans without the assistance of a tranny shop/technician?
Old 02-05-2010, 08:10 AM
rhandwor rhandwor is offline
Re: 1992 Ford E-250 trans replacement Throttle Valve cable
Check on http://www.ebay.com/ look for a used Ford Factory manual.
A lot of transmission specialty houses sell a manual just for this transmission.
Basically its getting the linkage correct so it shifts at the correct speed. A plastic grommet in the throttle linkage is a major problem area. The dealer used to sell them.
My Ford's always used a rod but on cars with a cable always buy a dealer cable as they are a lot better.
