Old 01-31-2010, 07:08 PM
gypsy07 gypsy07 is offline
99 3.8 fuel injector question
I have the fuel injectors out & want to thourghly clean them. (ruff idle, 240K mi.)
1. Can I apply voltage to them to open them up for maybe 10 seconds or so to run some cleaner through them?
2. From forum searches, 12 volts energizes the injector coil. Is this correct?
3. As I look at the top of the injector & the electrical connector is up ("north") which side is +?
Thanks in adv. for the help.
Old 02-01-2010, 11:59 AM
catvents catvents is offline
Re: 99 3.8 fuel injector question
This apply to 2001 year model ( according to my Ford electrical wiring diagrams book) but should be similar for 99 to 2003 model. The six injectors are feeded positivly (+12) all the time ( start or run) with the same wire ( color) ( red for the 2001 year model).
The other terminal for each injector is feed throught the PCM in correct sequence and duration with negative (-) and each wire has a different color for the 6 injectors. So locate which terminal has the same color for each injector so you will know which one is the positive side (+), red for the 2001 year model.
2001 Windstar
2007 Pontiac G5
2004 Freestar
1999 Ranger
Old 02-01-2010, 03:41 PM
Thanks catvents. I've somehow miss-placed my manual. I'll find it next week when I'm looking for something else.
