Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 01-31-2010, 10:59 AM
MWILKY MWILKY is offline
200 sunroof problems
have a 2000 tahoe with sunroof that has quit working. searched the forum but did not see any help in the past posts. i checked the rap fuse both inside the car and in the underhood box. anyone out htere have any advice or experience with this situation. the roof will not move at all, and do not here the motor working. help please.
Old 01-31-2010, 02:49 PM
Re: 200 sunroof problems
just a followup if anyone in the future has this problem. went back and pulled and checked all fuses. pulled switch from overhead console and checked continuity between poles with switch activated in each direction. checked ok. then listened to my wife and disconnected battery and reconnected. as bad as i hate to admit, problem fixed.
Old 07-17-2010, 10:45 AM
geopot geopot is offline
MWILKY,
Looks like I'm having the same sunroof problems with my 2000 Yukon. Just quit working and fuses seem to look OK. I too wanted to check the switch in the overhead console, but I'm unclear as to how to access it without breaking something in the process. Does the larger plastic cover simply snap on place, or is there a trick to getting it removed? Too many times I've pried at things that unfortunately went South and a little bit of information would have helped greatly.
Thanks for anything you and shed some insight on.
Regards,
George
Old 07-17-2010, 11:04 AM
I feel kind of silly, but give your wife a kiss from me. I disconnected the battery, let it sit for a while, reconnected, and the sunroof now works fine.
She's a genius.
Thanks again.
George
