Old 01-31-2010, 10:09 AM
gene56 gene56 is offline
order of pushrods
1994 pontiac grand am 3.1 engin.need to see order push rods go
Old 01-31-2010, 01:18 PM
3100 3100 is offline
Banned
Re: order of pushrods
Ok. here is the formula: look at your lower intake manifold, look where injectors go where you see injectors there you put intake push rods all others are exhaust push rods.
Old 01-31-2010, 05:44 PM
thanks so much.have 1 question are both side of engin the same
Old 01-31-2010, 06:56 PM
Banned
just look at the injector position inside of the LIM the way you would install your LIM and you will not make mistake. Yes both sides are same.
Old 02-03-2010, 04:43 PM
got engin back together.runs ok one problem idling is real fast
Old 02-03-2010, 04:46 PM
Banned
check that throttle plate cable is not stuck or that something is not pulling on it, also try relearning IAC by pulling e-brake shifting into D and let it idle until cooling fan comes on. Don't do this if you have weak e-brake.
Old 02-03-2010, 05:30 PM
tried ebrake not strong still idles 2500
Old 02-04-2010, 11:10 AM
Banned
look at the throttle boy see if it is open or closed, should be closed at idle. Did you check if something is pulling on throttle plate cable?
Old 02-04-2010, 02:29 PM
nothing holding throttle cable. will check throttle boy
Old 02-04-2010, 02:45 PM
ckd throttle boy it's closed would the catylic converty cause this problem
Old 02-04-2010, 02:46 PM
Banned
car was fine before you did this work so cat can't be blamed over night.
Old 02-04-2010, 02:55 PM
catyilic converter was cleaned out
Old 02-04-2010, 04:14 PM
Banned
Check that your iac is not disconnected (idle air control)
Old 02-05-2010, 05:03 PM
finally found problem.broken vacum line behind engin. cut off and reatached idle came right down were it should be. want to thank you for all your advice.If it was'nt for you car would not be fixed. again thank you
Gene56
Old 02-05-2010, 05:42 PM
Banned
No problem I wasn't much of the help in your case, but thank you for posting the fix.
Tags
order , push , rods
